apexi turbo timer info...
just because there is already a few great tech articles,im not gonna write onn, im putting this on the board for people who actually use the search button, before taking on this task..
things ive learned use friction tape..
dont cut your ignition wire and green wire, SHAVE the insulation...
dont settle for tape, solder, then friction tape over it
those of you getting a check engine code, i had the same problem, at anytime you have ANYTHING unplugged or cut, such as the guage cluster etc, do NOT put your key in the ignition/ twards the start, it scrambles up the computer, and you will throw all sporadic codes, i did this because it started raining and i needed to get my sunroof closed... if you follow the tech and do not put your key in the ig until your back togather and done with... your turbo timer will work flawlessly
even your remote alarm...
good luck if anyone needs to reach me id be glad to try and help, rolledthatho@hotmail.com
coocoomike
09-04-2003 12:29 PM
