turn signals stopped working. The relay for the turn signal is behind the hazard switch correct??
I want to make sure before i yank the trim piece etc. any tips appreciated.
so remove the hazard switch and the relay will be in there..? queezy wrote something about..
the hazard and turn signal relays being the same, BUT there being two. (he said he swapped the hazard switch in for the turn signal one as a temp. fix)
Its very simple to fix get a flat head wrap it in terry cloth...
pop out the trim its easy... on the right hand side of the hazard relay there is a little lever type thing its black push that in with your flathead and pull out the switch unplug the harness and plug the new one back in.... they can be had from the dealer for around 25+tax and viola your done
be sure when your poping out the trim...
that you pry it out equally on both sides becuz if you pull from one side it will crack or break. I took the flathead wrapped in terry cloth poped out one side then held it out and went to the other side it should pop out easily good luck
chapman62083
01-25-2012 10:51 AM
Slave IV
9
07-31-2007 02:39 PM
DashingMax
11
12-13-2004 05:57 PM
