: : Updated DIY Head Removal and Installation Writeup : :(wiki)
<center><img src="http://img.photobucket.com/albums/v673/Rosati/head3.jpg"></center><p>
<a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v673/Rosati/head2.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Since quite a few guys asked me how, plus the fact that I didn't have a writeup to follow when I had to remove my head in my driveway, I just had my guys on AZ/AW. So as a token of thanks, I just threw this together to avoid future repetitive questions.
It wont be perfect, But here we go:
Do you have to remove the timing belt to take off the head? Yes and No.
I do not remember the exact allen sizes because I bought the Switch-out allen key tool from Autozone, this helps tremendously and is only $10, Everything else is off the top of my head.
Plan to take everything apart , unless you know the secret to put the belt on w/o putting it in service position, i know how to do it , but didnt have the tools, the hard part is putting the belt back on out of service pos. and tensioning it w/o the right tools, but dont sweat it.
There are writeups for the Timing belt, but not for head removal.- Plan on putting the car in service position, then work on the head. Get down to the timing belt (service position) Then just remove the Hydraulic dampener and take the belt off - Dont forget the cam sensor . If you are in a rush,and are replacing the belt you can CAREFULLY remove the belt from the cam gear-- Pull side to side then easily use a blunt object to slowly push the belt off the teeth, side by side, carefully and slowly.
Once its off , start disconnecting the exhaust manifold bolts first-The bolt (size 17) nearest the head is a toughguy, use a small ratchet in there and remove it while it still has room to be pulled out, then use an open ended wrench to take it out.
After the EM, start at the Throttle body , remove hose and throttle body (4 screws, size 6 or 8 allen i believe) Remove throttle cable and 2 bolts holding it in. Unhook cruise control nipple. Now is the time to remove the lines under the Intake manifold. There are two. Remove those hoses easily and disconnect throttle body sensor wire.Now remove the 10mm Allen bolt for the IM brace. Then, work your way to the black cooling line that runs from the upper rad hose. Remove those screws holding the metal hose down to the IM. Then there is a connection at the corner of the head that goes down to the filter . Disconnect that hose (using pliers), then start working at the rear head coolant flange. 2 size 10 bolts await you. Try to unscrew these with care, they are sensitive and so is the flange. After that, remove remaining hoses from Coolant flange, 2 I believe , 1 rear , 1 right side. Replace all those gaskets and do not lose clips. Pull and replace Coolant temp sensor while you are at it.
While back there, remove the 2 10mm bolts that connect the rear head flange to the radiator hose. After that, remove the bolt holding down the metal coolant line going across the head and swing out of the way.
Remove Fuel rail and injectors. Youll need a 6mm Allen to get the 2 bolts holding down the rail. After they are out, the injectors pop out with a straight pull. Now remove the 10 10 mm bolts holding down the VC. After that, remove coil pack ground (size 10 as well) then, remove coilpacks and peel them back , resting in them behind the firewall. Remove PCV line that is bolted to VC ( 2 allen bolts) Remove valve cover and carefully set aside, upside-down. Your almost there.
Now: Onto removing the headbolts-
There are two tools that are required for some.
For earlier B5's (97-98.5, maybe 99.5), you need those two. (Go figure)
First, Go to Napa. Get their headbolt kit (GM) , Its cheap. You are looking for a 12 point.
One of the 5 tools is going to fit our headbolts. From there the tool is short, It'll only remove the center headbolts and not the bolts in the corners of the Head, as they have a deep well. Well, To solve this problem, I welded a ratchet extension onto the tool itself. ( Or pay someone, cant be more than $5) Make sure they (or you) grind down the weld in order to avoid scraping the walls of the head.
Newer B5 Guys:
You need this Poly-Drive tool: <a href="http://photobucket.com" target="_blank"><img src="http://www.zdmak.com/wbstore/images/T10070AAA.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
You can get it from ZDMak or PureMS - I strongly suggest PureMS (contact Mike)
I do NOT recommend buying from ZDMak. They took 2 weeks to ship my tool. Yes, I had my head waiting to be pulled for 2 weeks-Luckily I had an extra car. If you can get it from someone else, then great. If not, demand prompt shipping w/ a phone call.
Removing the headbolts requires a removal pattern in this order:
(Intake cam being the Bottom Row)
1 7 9 5 3
[4 6] 10 8 2 -- Parenthese= Plastic Splash cover
They loosen up easy, but make sure you keep unscrewing, as the threads are long.
And her head's off.
<a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v673/Rosati/TBwentwrong.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
While you have the head off, now is a great time to replace a few more things and one mandatory thing:
-I cleaned my squish area just a bit and as well as the surrounding area. Some may argue that it needs to be dirty to form a nice seal, But after cleaning mine, I had zero issues.
-Replace stock oil feed line to the turbo
-Replace PVC pipe from the block , Part number 058 103 213 (wasnt expensive)
<a href="http://photobucket.com" target="_blank"><img src="http://www.scottweese.com/images/pcv/old_new.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
This is a Huge culprit to boost loss and very hard to replace w/ the IM on.
- And the mandatory part, you guessed it, The Head gasket ($60)
When you are ready to install the head, installation is reverse of removal w/ a few exceptions:
-Remember to PROPERLY install headgasket right-side up with Audi VW emblem facing UP in the lower right corner, quite a few people had made this mistake and had to repeat the process all over again.
-Replace coolant
-Remember to replace all coolant line and flange washers
And most importantly,
Install Headbolts in this specific order:
Intake cam being the bottom row-
10 4 2 6 8
[7 5] 1 3 9
Start w/ your regular 1/2" ratchet then torque to 44 lb Ft (60 NM) After that, Take your Regular half inch ratchet and Give an additional HALF TURN. I used two quarter turns for extra control.
- Try to get some help installing the Head if you can- youll need it when trying to line it up with the points.If not, then just take your time lining it up to the exact set point. After it is set, test to see if the head easily moves out of place, if it does, then its not in the right place.
Before you put the VC on, pour some oil over the cams and valves for startup and start connecting the exhaust mani and the rest after you set the Timing belt to TDC and your all done and saved yourself massive amounts of money.
And thats it! Whole process maybe took an hour and a half , wasnt hard right?
<a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v673/Rosati/04-21-07_1534.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
NOTE: When setting engine to TDC, set crank a few teeth before TDC if the head isnt already at TDC. This will avoid any compression and allow you to adjust the cam sprocket accordingly with the safety of avoiding the bending of valves.
Now enjoy putting everything else back together!
If you have any further questions, Im me on AIM or PM me.
I will be editing and adding to this if needed, so no sticky/writeup yet
Rosatomafia20- Aim Rosatomafia20@yahoo.com Email
Newer B5 Guys:
1 7 9 5 3
And her head's off.
-Replace coolant
10 4 2 6 8
[7 5] 1 3 9
eCoastAudi
01-18-2008 10:25 PM
Rosati (Ginzo)
08-15-2007 02:04 PM
aerohr
09-07-2005 11:01 PM
Audi-Impaired
07-08-2002 04:41 AM
