VAG port still not communicating
Audiworld Senior Member
My car still won't pass emissions b/c the testing center's (garage) emissions system still can't talk to my VAG communications port. Originally I thought it had something to do w/the fact that my ABS ECU was dead (ABS & brake dashboard lights on), but I've since had my ABS ECU repaired. Granted my radio is still dead, but since it's in the 'OFF' position, it shouldn't effect the VAG communications (or lack thereof). So what do you guys recommend next? Do you think the actual communications port is faulty? We did successfully connect to it once or twice, via a cheapo OBDII piece of hardware, but typically get "NO LINK", which is obviously the same problem the emissions tesing center is having. Annoying!
Thanks,
Thanks,
JT
02-03-2009 11:12 AM
Another ABS question - VAG cannot communicate with my ABS module, but I don't get a light and ABS...
DWP
01-23-2009 02:46 PM
Throwin on vag com - Powertrain data bus: missing message from abs controller...what does this mean?
Seabeast11
04-04-2007 09:03 PM
kookie
07-25-2005 06:30 PM
Matt E.
02-01-2005 05:40 PM
