Vagcom code 17963: Negative Deviation
Old Sep 15, 2004 | 10:07 AM
wakko's Avatar
Default Vagcom code 17963: Negative Deviation
I just vagcom the car on my way to work and on 3rd gear going WOT, I got this code after the run. During the run, I was holding boost at 15-16psi, and after the run, it couldn't go pass 7psi.
17963: Charge Pressure Control: Negative Deviation
However, after 4-5 mins later, the car seems to go back to normal and able to hold boost to 15 again.
some suggestions that I found from the search
- check bpv / vac lines (I have a Forge 007 and changed the vac lines 3k ago)
- wastegate line (will check this one)
- sticky wastegate (seems like it could ruin the turbo)
- MAF (last I did vagcom, it was max at 140g/s at WOT w/ my GIAC 1bar chip) I guess this could be the problem too
anymore suggestions that I should check to tackle this problem?
thanks
Old Sep 15, 2004 | 10:32 AM
SilverA4Fun's Avatar
Default limp mode from a vac leak..check the "L" shaped hose that runs from your
intake manifold back towards the firewll by the coolant resevoir.
Old Sep 15, 2004 | 10:38 AM
audiohs's Avatar
Junior Member
Default I know someone who got the same code
He checked and changed a lot of the things that you mentioned. In the end, he had his GIAC chip updated to the latest version and it's been fine since. He also has a 2000 1.8T. What's weird is why it would do it all of the sudden. He had been running that chip for at least a year without any problems (he bought the chip and ecu used).
Old Sep 15, 2004 | 12:42 PM
wakko's Avatar
Default good call, I have had my chip for 2 yrs and never had an update
I forgot to mention that to update this program. Thanks, audiohs
kgardnez
Mar 26, 2011 05:59 PM
wakko
VAG-COM Discussion
Sep 15, 2004 10:07 AM
Kirk
Performance and Tuning
Jun 2, 2003 08:29 AM
Kirk
May 8, 2003 12:02 PM
VenomousA4
May 5, 2003 10:03 AM
