VCDS won't has error while trying to do TBA..
Old Apr 30, 2012 | 03:23 PM
HzDrgr's Avatar
Default VCDS won't has error while trying to do TBA..
So after having my battery unhooked to remove my airbag so I could replace my ignition switch.. I started my car and it was running like complete garbage.. Scanned with VCDS-Lite and come up with these codes..
Monday, 30 April 2012, 18:53:57:31879
VCDS-Lite Version: Release 1.1
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR HS D03
Software Coding: 06201
Work Shop Code: WSC 06335
VCID: 6CAB3B340F85
3 Faults Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-00 - -
16507 - Throttle Position Sensor (G69): Signal too High
P0123 - 35-00 - -
I cleared them and only the p1545 comes back immediately. So I figured I needed to do a TBA. I tried doing a TBA and VCDS doesn't do the TBA, but it says error. the two voltages say 5.100v, then it says part throttle, then error. It displays this in measuring blocks, and basic settings. I then tried cleaning my throttle body, thinking the valve might be stuck.. I still get the same thing. Any help here would be appreciated. I am at a loss.
Old Apr 30, 2012 | 03:39 PM
HzDrgr's Avatar
Title should be VCDS has error while trying to do TBA..
Don't know how that happened
Old Apr 30, 2012 | 04:25 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Not that it helps now, but there is no point in disconnecting the battery to work on the airbag system. Shutting the key off is enough.
Are you using VAG-COM or something else? Following the directions on the Ross-tech site?
Old Apr 30, 2012 | 04:38 PM
HzDrgr's Avatar
Oh, I was under the impression that I should disconnect battery whenever the airbag is unplugged.. anyways.. I'm using an legitimately activated copy of VCDS-Lite.. Car was running fine up until the point where I had to change my ignition switch.. Is there a possibility that my throttle body is cooked? or my ECU? I have followed the directions on the Ross-Tech website exactly.. The only thing that could be stopping it I guess would be the codes?
Old Apr 30, 2012 | 05:01 PM
4Driver4's Avatar
Tech Guru
Tech Guru
All codes must be cleared prior to adaptation. Other than that, I'm not familiar with the lite version and its capabilities.
But on the battery/airbag thing: no. Makes no difference.
Old Apr 30, 2012 | 05:04 PM
HzDrgr's Avatar
That's mainly the problem I'm having I guess.. the P1545 comes back immediately after clearing.. which makes me think the valve controller on the TB is Kaput?
Old Apr 30, 2012 | 05:20 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Hard to imagine it was fine prior to the airbag issue though. Weird.
Old Apr 30, 2012 | 05:25 PM
HzDrgr's Avatar
I know, that's why I'm stumped. I did some research and found that the p1545 code is common after an unhooked battery.. which is why i wanted to do the TBA to begin with. But since the code keeps coming back wouldn't it be impossible to do the TBA anyway? How would I keep the code from recurring so I can to the alignment?
Old May 1, 2012 | 04:54 AM
GTA_Driver's Avatar
Tech Guru
Clear the code and right away perform TBA? Otherwise take it to a good Audi shop, perhaps te dealer and ask them to perform it for you.
Old May 1, 2012 | 05:02 AM
HzDrgr's Avatar
I have tried that, and it still does not work. The code comes back Immediately.. like within a second. The only way i can get it to say anything other than error, is to actually start the car, then shut it off and try to TBA. And it almost looks as though I might have to do that.. too bad it's running too poorly to even drive, I'll have to have it towed.
