VDO Boost gauge question
Whatever comes in the tubing kit... I think 1/8. (more)
It looks like the fitting in the tubing kit is designed to be threaded into the intake manifold. I would rather splice into one of the hoses with a T connector, which typically have the push-on barbed fittings. So how to go from the 1/8 nylon tubing to the T-connector?
so you buy like a foot of 3/8 hose..
use a 3/8 nylon T for the vac hose, cut a little piece of the 3/8 hose you bought and adapte the 1/8 hose that comes with it,
just make sure the inside dia is correct and it's a tight snug fit., then zip tie every join to make sure
I converted the nylon tubing (1/8") outer diameter to
rubber tubing with a 1/8" inner diamter once I got the nylon tubing into the engine bay. Slide the nylon tubing into the rubber tubing and zip tie it...Now you have tubing to fit on the outside of the T like the hose your tapping into does.
quattro_silver
06-16-2008 06:17 AM
MaXiTT
10-19-2004 05:37 PM
[Arawan]
04-19-2004 03:04 PM
JKim1.8T
05-06-2003 09:08 AM
JKim1.8T
04-22-2003 06:36 AM
