vdo boost gauge question
purems.com sells a boost gauge install kit. $10 or so
so does http://www.42draftdesigns.com/
the vacuum line is 5/32" in our cars, so you need to tap into that line, and run it to your boost gauge. some people run a smaller line from the tap to avoid buzzing, and/or use a buffered tap. the purems kit includes a smaller line. buffered tap is extra.
the vdo boost guage has a pipe fitting thread connection on it...
you need to convert that to a hose barb connection, then Tee that hose into a vac line off the manifold.
here are pics of wha the AWE VDO kit comes with:
<img src="http://www.modifieda4.com/images/boostgauge-install/DSC00593.sized.jpg">
<img src="http://www.modifieda4.com/images/boostgauge-install/DSC00600.sized.jpg">
Plastic T will especially become brittle when tied off to a hot coolant hose.
It's terrible to tie off a plastic T to something hot on the engine, agree? I used a plastic T for my setup, and it has lasted over 9 years,no brittleness..if that is a word. He should undo that and run it like most people do.
J
J
microa4
08-21-2001 12:23 PM
S4NoRice
20
07-21-2001 02:01 PM
audiohs
06-15-2001 09:49 AM
