weird stalling problem ( longish)A4Q 96
i am sure 1 of you guru's will be able to help description of problem, this happnes only when temperature is around below -10C over 0C it does not happen at all, the car will starts just fine ( even at -30C)and warm up and idle fine , then i slowly take off to work ( or play)it will drive fine but when it get to normal temperature it will idle very low and stall or alternate between stall and run, if it stalls it will restart just fine but I have to keep the gas on , there is no DTC and I have scan the car and no DTC either, anyone ever experience that,,, what is wrong
Sfeezy
02-09-2004 12:13 PM
