What did you use Goof off or Goo gone for debadging? Or does it not matter?
I used WD-40...might try goo gone...
as the WD-40 was slow going. I was probably a bit too abrasive and should have taken more time.
Be gentle, go slow. Heat it up well with the hairdryer and try to get most adhesive off with the first swipe of your dental floss.
Plan of 30-45 minutes, total job.
When done, wash down the area and apply wax.
Damn... mine took me about 10 minutes total...
I got dental floss. That broke so I went and got some fishing line.
Fishing line worked perfect after I heated it with a ceramic heater (a good bit hotter and less air flow than a hair dryer)...
I then used some generic "tar and bug remover" and the adhesive litterly peeled off after I saturated it with the remover solution.
YMMV, especially since mine was a 2001, the badges probably weren't baked on as badly...
Great, I'll keep that in mind for Avant #3..
I took the easy way out for #2 and asked a friend at the bodyshop to use the rubber wheel they have to do this. They work incredibly fast and leave no mars or scuffs. All it cost me was a thank you too!
Thanks for the tip,
Peter
Thanks for the tip,
Peter
