What was the problem??
Old Sep 11, 2002 | 04:38 PM
Prok's Avatar
New Member
Default What was the problem??
Yesturday my sister was driving my car with me. She stalled the car then started it back up. We went driving not even a block and she said that the clutch wouldn't move back out. So we pulled over to the side of the road and I looked at it. I pushed the clutch in and it wouldn't pop back out. Their was a gas station near by and so I pushed the car into their. About 5 min later the clutch was working properlly. I pumped it about 5 times then it started sticking again. everytime i would pump it, it would slowly not come back out as far to finally i pushed it in and just stayed in. Then about 5 min later the same thing happened. I thought I would drive it cause if I just didn't push the clutch in to much that it would be fine and if it did stuck i would just push it out with my foot. I drove and it was fine. We then went for dinner and came back out and drove home. When i got home i went out and pumped it about 100 times rapidly and it didn't stick or anything. Like it was completly normal again. When i was at the gas station i checked to see if the hydrolic fluid level was fine and it was. I was wondering if anyone has had this problem and if they know what it is. Could it be air in the clutch line. I just want to make sure that their is no damage going to be done in the long run. Thanks
Old Sep 11, 2002 | 06:10 PM
dstech's Avatar
New Member
Default Check the joint pin for pits or obstructions. You might have a bad master cylinder.
My clutch squeaks every 3months and I have to get down and grease it each time. The pin is starting to show some wear. I think it's possible for this pin to become deformed, which might cause a sticky clutch.
Parikh1234
RS4 (B7 Platform) Discussion
22
Oct 9, 2006 09:48 PM
Euro'd
Jun 8, 2006 02:41 PM
Matt2.8.. Evoluzione
Jan 11, 2004 07:40 PM
Octane
Apr 25, 2003 10:55 AM
HokieS4
11
Jul 21, 2001 09:15 AM
