Where can I find MAF "tamper proof T15 torx" screws
You dont need one to remove the maf housing out of the air box
thats all you need to remove and just leave the maf sensor in side the stock housing. YOu just need to take all of that and just stuff it between the pipe you bought and the stock hose you have that pipe on right now. Just make sure you put the maf so that the screen is facing the new pipe or filter and the arrow on the maf housing is facing toward the turbo/intake manifold or the direction the air is moving toward the motor.
well... for a custom turbo set up, like this, you might need to allow a higher airflow.
the stock MAF housing could limit the airflow.
<img src="http://pictureposter.audiworld.com/57353/524.jpg">
I know that the pictured turbo set up doesn't have a MAF but if you where to build a similar set up with a MAF you'd need a larger diameter MAF housing
Chuck-S4
42
05-10-2005 01:24 PM
Phil type 951
01-11-2005 05:25 AM
PSmalls::DoggieStyle
70
08-26-2004 06:55 PM
Psssst!
21
02-25-2003 04:49 AM
