Width and offset question
Old Nov 8, 2001 | 01:53 AM
Gold A4's Avatar
New Member
Default Width and offset question
I've decided on 17" somethings for my stock 2001 A4. Now when choosing a wheel, what width should I be looking for? Also, what "offset" range will I be safe with? I really don't know what offset is or what it presently is on the 15"OEMs I have. Help me understand this, please.
Old Nov 8, 2001 | 02:10 AM
Joe (zyxt)'s Avatar
Junior Member
Default Info:
Not sure on the stock 15" and 16" rims, but:
Stock 17" rims are 7.5" wide with 45mm offset. This results in the rims being pulled in a little inside the wheel well.
In my personal opinion, the best look and fit is achieved with 8" wide rims with 35mm offset. This puts the rims just about flush with the fender, and still fits like a glove. This is what I've got, and I've got my car pretty low. No rubbing problems at all.
You can of course go wider, but you might have to roll the fenders at that point, depending on how low you plan to drop the suspension. There are many people who run 8.5" wide rims with 32mm offset. Those rims stick out just a *tiny* bit, but it's enough to cause rubbing if you lower the car enough and don't roll the fenders.
Old Nov 8, 2001 | 02:18 AM
Joe (zyxt)'s Avatar
Junior Member
Default More info:
Did you also want to know what offset was? Offset is how far off from center the hub of the rim is. This basically determines how far the rims stick out from the car.
A zero offset means the hub is right in the center of the rim. As the offset becomes positive, the hub moves towards the outside of the rim, thus pulling the rim in towards the car.
Old Nov 8, 2001 | 02:20 AM
Joe (zyxt)'s Avatar
Junior Member
Default Check out TireRack's site for some good diagrams and such...
<ul><li><a href="http://www.tirerack.com/wheels/tech/offset.htm">http://www.tirerack.com/wheels/tech/offset.htm</a</li></ul>
trombs
Q7 MKII Discussion
May 15, 2016 06:53 AM
Lewayhun
Sep 26, 2014 04:43 PM
hhh1855
Apr 25, 2011 07:49 AM
RichcoupeGT
9
Jan 11, 2004 08:27 AM
greenaudi100
Audi 100 / A6 (C4 Platform)
Aug 26, 2003 06:32 AM
