will bigger rotors make a decent difference
can i just put on bigger rotors on my car or do i have to make some sort of changes to accomidate them. and if i did this would there be any benefit at all?
need to make other changes
bigger rotors are usually wider, which means you need to adjust the caliper carriers. not not mention those needs to be adjusted for the placement of the caliper on the rotor
the cheapest method is the A8 upgrade. tech article explains it.
Need at least new caliper carriers...
You will need at least new caliper carrier brackets to position the caliper farther out from the axle. Also, you must be sure that the larger setup will clear your wheel rims.
Larger front rotors give you improved stopping from freeway speeds and improved heat resistance for repeated hard braking. Around town your braking distance is limited by the tires. The downside is more mass and rotational inertia.
Read the tech article; if you want the most bang for the buck . . .
Go for the A8 rotor/TT caliper upgrade. I heard one person get the parts for as little as $400 and change.
If you want a real big brake(super street or racing track quality) upgrade you will look between $1500+ on the low end and $4000+ on the high end.
I am looking at keeping my calipers and getting just the A8/TT component upgrades.
greenaudiurs4
Audi Original "S" Cars
11
10-16-2007 06:37 PM
bugzy SoCalEuro.com
03-15-2004 09:22 AM
So if I want to upgrade to A8 rotors, all I need are A8 rotors and TT carriers from the dealer right
Liam in Montreal
06-07-2002 08:06 AM
Dieselino (Jeff)
02-09-2002 07:11 AM
