will i need a different front bumper (other than stock) to fit APR FMIC?
im lookin at this setup because of the oktoberfest 10% off on intercoolers sale APR is having. i looked at the fitment and it says a new bumper like the S4 bumper is needed. can you not just cut the stock one to fit the FMIC?
TIA
TIA
here is the pic
<center><img src="http://pictureposter.audiworld.com/8932/apric4.jpg"></center><p>do you like APR's design because of the vertical flow? If so I don't think there is anything else available like that right now. I would serisouly consider the Tyrolsport side mount if stock bumper if your thing.
or try this one
<center><img src="http://tyrolsport.com/smic4.JPG"></center><p>depsnding on the cost, if I wanted to keep a stock bumper, I would probably look at something like this .<ul><li><a href="http://tyrolsport.com/sidemount.htm">http://tyrolsport.com/sidemount.htm</a</li></ul>
Odd, I hate APR's design. I can't understand why they didn't go with a Z-flow style.
All they need to do is flip the one of the end tanks before welding. It makes absolutely no sense to have both the inlet and outlet on the same side for these cars, unless your trying to show off your pipe bending skills. So much more plumbing is required with their style and I would think more air would pass through the core on the inlet/outlet side reducing efficiency.
thanks for the info. im not bent on APR, i just need something that flows a lot more than stock
SMIC. im tryin to piece together a K04/j31 setup and ill need a new IC. ill keep looking around.
