2.7t block on a 03 a4 3.0???
hey i was wondering if i can slap the 2.7t block right on my 03 a4 3.0? and also can i slap a 2.7t clutch and flywheel on my a4 tranny?
Clutch/Flywheel get bolted to the motor not the transmission. So if you go with a 2.7t engine you need to use a 2.7t flywheel/clutch. Transmission will work no matter what since they all have the same spline on the input shaft.
The 2.7t clutch/flywheel setups will work on the 3.0 engine.
thats great to hear thank you i just got a 2001 a6 2.7t off copart for dirt cheap im gunna rip the motor out and swap blocks and boost my 03 a4 and have eurodyne make up a tune for me i also have a 2000 s4 that im trying to figure out some good mods for i already got apr down pipes front mount forg d/v's and the stage 2 ecu will be here soon.
also i see you said the 2.7t clutch/flywheel will fit the 03 a4 3.0 motor? are you totally sure on that cuz mine is messed up in my a4 and the 2.7t clutch and flywheels are alot cheaper then the 3.0 so i can just do a staright swap then?
Z-Tuned (Alex)
11-08-2008 07:05 AM
Ren_2.7T
03-19-2008 06:10 AM
Grenade
03-27-2007 06:12 AM
myfirstimport
01-19-2004 02:35 PM
Audi_Seadog
03-17-2002 09:55 PM
