2004 1.8t running rough
Hi all,
I recently purchased an '04 B6 1.8t Quattro with the BEX engine. It runs very rough, shuddering and stalling at idle.
I've done the basics:
- new spark plugs and coil packs- Injectors professionally cleaned- checked fuel pressure with gauge (65psi to the fuel rail)- replaced pcv system (damaged hoses, pcv and prv valves)
- charged battery to 14 volts- replaced crank sensor- cleaned all the grounds I could find- replaced fuel pump relay- checked all engine fuses and confirmed they are getting 12v
The below engine codes have persisted throughout my owning the car, I've cleared them multiple times.
The fuel pump relay is getting 12v, and I'm getting 65psi of fuel pressure to the rail. I've tried switching injectors 1 and 2 with 3 and 4, still getting open circuit on 1 and 2. All injectors have around 12ohms of resistance and are getting 12v when cranking the engine. I've also tried a new wire from the injector 2 ecu pin to that injector, and grounding the other side of it to the engine bay, same code persists.
Hoping someone might be able to point me in the right direction with troubleshooting this!
SC_09iduA (03-11-2023)
Sorry I can't help. I have always been my weakest at trouble shooting electrical. You have done all the things that I would have tried.
My D connectors were crumbling like many have said for a 20 year old car. Now I found the perfect size heat shrink tubing and heat shrink them. That took care of alot of my electrical issues.
If you have an stethoscope then you can listen to injector body to confirm if they are firing or not.
Hi guys, thanks for all the replies I've been away for a while and haven't been able to get to the shed!
I can confirm the continuity on all the injector ground wires is 0.05.
Injectors 1 and 2 are definitely not firing, I've got the 4 of them set up to shoot into bottles. They are all getting voltage and if I borrow the ground wire from injector 3 and stick it on injector 2 it will cause that one to fire. So the ECU is not pulsing ground to 1 and 2. I've also tried rewiring the injector 2 ground wire from ECU to injector.
Had a guy come out recently and test the ECU, he couldn't find any issues with it and indicated it should work fine.
Are there any sensors which might shut down the first 2 injectors if it fails, or maybe a ground which might be worth me rewiring?
xBLACKx
04-25-2010 11:11 AM
DRennick
05-11-2002 07:11 AM
