Audi A4 1.8T Catalyst Help.
Hi guys,
So i'm having a problem with my Audi A4 04 1.8T. Since a month my car seems to shut down after 30 to 40 min ride. Ive changed my fuel pump and my fuel filter. My spark plug and coil are still good.
My garage told me my catalyst is the problem. Im having lost of power and the engine shut off after. Its an automatic.
Would a new cata solve the problem for real ? Just want to be sure before buying it !
Thanks guys here are the code Im having.
16684 - Passive/Sporadic - Random/Multiple Cylinder, Misfire Detected-Implausible signal
16686 - Passive/Sporadic - Cyl2, Misfire Detected- Implausible signal
16804 - Active/Static Catalyst System Bank 1 Efficiency Below thresfold Lowe limit not reached
17536 - Active/Static - Bank 1 mixture adaptation (mult) system too lean Upper limit exceeded
17519 - Active/Static - Oxygen sensor control (Bank 1) System too lean Lower limit not reached
caypann05
01-14-2011 03:59 PM
wcostello
VAG-COM Discussion
03-07-2008 04:41 AM
