On breaking in the engine...
Old Feb 9, 2002 | 05:36 PM
Audifourme's Avatar
Default On breaking in the engine...
For the first 1,000 miles:
1) Don't get engine RPM's above 3,000
2) Vary engine speeds, i.e. never run at fixed engine speed for a long time as on the highway using cruise control
3) Don't apply Wide Open Throtle
Am I forgetting something?
What else would you add?
02 1.8TMSXB Dolphin
Old Feb 9, 2002 | 05:39 PM
ErikNYC's Avatar
Member
keeping it under 3000 RPM is going to be really hard. I'd shoot for 4000-4500 as your limit
Old Feb 9, 2002 | 06:15 PM
woofpup's Avatar
Senior Member
Default Re: On breaking in the engine...
Actually, just follow what your owner's manual says.
And, as has been discussed before here, you should NOT limit your RPMs during the whole first thousand miles. You want to make sure your engine is broken in along the range of RPMs up to near redline. Go easy on it at first, but gradually keep increasing your maximum RPMs over the first thousand miles. There was a whole article someone posted on breaking in all four-stroke engines, but some of it was questioned by those on here.
Old Feb 9, 2002 | 07:52 PM
Robert F's Avatar
Junior Member
Default Put it through its paces from 1000 - 5000 miles...
...or it will not break in right and likely will wind up going through oil much faster. Don't beat the hell out of it, but as woofpup says, "do use the full range of RPMs". That's how I broke in my 2001, and it goes through less than 1 quart of oil every 10,000 miles. (31K now).
Personally, I would strongly recomend switching to Mobil 1 @ 5000 miles, and changing the oil every 5000 thereafter.
rush4yu
Audi A3 / S3 / RS 3
May 3, 2006 08:08 PM
pastabatman
10
Sep 5, 2003 10:52 AM
Mike@Ikon Motorsport
21
Mar 14, 2003 07:53 AM
SpoonZ-1.8t
Sep 21, 2002 04:21 PM
Miguel R.
Mar 21, 2002 08:51 AM
