Bumper Misalignment
Old Sep 30, 2008 | 11:34 PM
YYC_A4's Avatar
Member
Default Bumper Misalignment
Hello all,
After having my head gasket replaced by the dealership, I've noticed that the top-passenger corner of my front bumper is no longer properly aligned (see photos below, it's more pronounced when viewed from certain angles). Is this a simple adjustment (as in DIY) or should I insist that the dealership correct their mistake (at the risk that they might ruin something else)?
Thanks,
YYC_A4
<a href="http://pictureposter.audiworld.com/140986/img_0418.jpg">
<img src="http://pictureposter.audiworld.com/140986/img_0418.t.jpg">
</a>
<a href="http://pictureposter.audiworld.com/140986/img_0425.jpg">
<img src="http://pictureposter.audiworld.com/140986/img_0425.t.jpg">
</a>
<a href="http://pictureposter.audiworld.com/140986/img_0429.jpg">
<img src="http://pictureposter.audiworld.com/140986/img_0429.t.jpg">
</a>
Old Oct 1, 2008 | 04:25 AM
QuattroFan02's Avatar
Member
Default You can remove your headlight and reach down and loosen 3 nuts down the fender side
that hold the bumper down. Bump it into place and retorque nuts.
Old Oct 1, 2008 | 04:53 AM
heateris's Avatar
yep, or thru the wheel well, just pull back the fender liner.you'll need torx bits and deep sockets
Old Oct 1, 2008 | 09:17 AM
Bronze's Avatar
Senior Member
Default Before you remove anything, I'd get a towel and a rubber mallet and give it a
few whacks. You're probably talking about bringing it in about 1 mm, and that's within the flex of the fascia.
Think of yourself as using time honored techniques of master craftsmen handed down through the generations.
Old Oct 1, 2008 | 09:42 AM
Member
And you would do this to your own car?
Old Oct 1, 2008 | 10:41 AM
quattrothatcould's Avatar
Default BTDT
To the unpainted lower area..
Old Oct 1, 2008 | 10:54 AM
Bronze's Avatar
Senior Member
Default Sure. Have you ever been to an automobile assembly plant? You would be
surprised at what you see if you think a rubber mallet and a towel is crude. They don't use towels.
Old Oct 1, 2008 | 11:02 AM
YYC_A4's Avatar
Member
Default Ok, after removing the passenger-side headlamp...
...here's what we've got:
<a href="http://pictureposter.audiworld.com/140986/img_0431.jpg">
<img src="http://pictureposter.audiworld.com/140986/img_0431.t.jpg">
</a>
<a href="http://pictureposter.audiworld.com/140986/img_0430.jpg">
<img src="http://pictureposter.audiworld.com/140986/img_0430.t.jpg">
</a>
I've tried loosening the nuts, pushing the two pieces in-line and tightening, however, it just springs back - which leads me to believe that the cause is elsewhere.
I think we need to try the less vicious options first; the rubber mallet might do more harm than good in this case.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 1, 2008 | 11:12 AM
Member
Default Then you're going to need to loosen the two large allen bolts at the front
that hold the bumper to the impact buffers. Go to A4mods.com for a diy that shows you where these two bolts are.
Old Oct 1, 2008 | 03:11 PM
seencats's Avatar
Default problem is that you left the dealership
they could say that there is no proof that they messed it up and that you could have done it. Which is not the case but it is a technicality.
uble1234
14
Oct 23, 2020 08:07 PM
random512
A6 (C7 Platform) Discussion
11
Oct 1, 2019 08:03 AM
gruvenparts.com
Oct 11, 2016 04:47 AM
Thomas George
Auto Detailing Discussion
Sep 27, 2015 06:59 PM
Audigirl121
Want To Buy - Archive (NO NEW POSTS HERE)
Sep 26, 2015 12:51 PM
