Can someone with a 2003 A4 do me a favour? Please check your fuse panel and ...
...tell me how many amps fuse #37 is?
My fuse #37 (pictured below - Intelligent Electronic Module) is 20 amps. But someone said that there is a TSB stating that fuse #37 should be swapped for a 25 amp fuse before delivery. Can anyone confirm this?
<img src="http://www3.sympatico.ca/ralphkaram/aw/fusebox01.jpg">
Re: Can someone with a 2003 A4 do me a favour? Please check your fuse panel and ...
I had the washer fuse blow today. I have a 2003 A4 1.8T. The fuse was a 25A not a 20A. I suspect the fuse blew because of the air temp was 12 degrees and I had my headlights on so the headlight washer came on along with the window washer for a brief moment before the fuse blew. There is a TSB regarding increasing the amperage of the fuse. However, under some conditions the 25 amp fuse can also blow.
jamile222
09-29-2015 11:22 AM
hoppedallroad
09-21-2015 10:03 AM
PaulNZallroad
Audi allroad
09-17-2015 04:46 AM
ryoung
Wheels & Tires Discussion
12-19-2001 07:44 AM
