Code help please
Old Jun 5, 2008 | 11:56 AM
user 7208203's Avatar
Banned
Default Code help please
My car had a check engine light on but seemed to be running fine. My friend just scanned it, and here are the errors it kicked out:
4 Faults Found:
17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
P1111 - 002 - Lower Limit Exceeded - MIL ON
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - MIL ON
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0000 0000
Any ideas?
Old Jun 5, 2008 | 12:07 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Lookee here-
-<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
Old Jun 5, 2008 | 12:11 PM
Banned
Thanks
Old Jun 5, 2008 | 12:55 PM
Bronze's Avatar
Senior Member
vacuum leak for starters. Check your hoses, especially the little braided ones.
Old Jun 11, 2008 | 08:51 AM
Banned
Default Update
Turned out to be a vacuum leak through a cracked check valve.
Old Jun 11, 2008 | 10:43 AM
Bronze's Avatar
Senior Member
Amazing how one little cracked piece of plastic sets all those codes.
brandonb93
A4 (B7 Platform) Discussion
12
Dec 4, 2018 01:16 PM
mxp
Sep 26, 2015 10:15 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
Sep 25, 2015 08:57 AM
ECS Tuning-Audi
Sep 25, 2015 08:20 AM
mdkv5
A6 (C7 Platform) Discussion
Sep 16, 2015 01:09 AM
