coilover question
Old Feb 11, 2004 | 07:20 AM
sbh tuned's Avatar
Default coilover question
I know you can be slammed on C/Os, but what is the max height that you can go on them? Comparable to sport, non-sport?
Old Feb 11, 2004 | 07:22 AM
alipor's Avatar
I think most of them are a couple of mm lower than sport.
Old Feb 11, 2004 | 07:29 AM
sbh tuned's Avatar
ok thanks
Old Feb 11, 2004 | 07:44 AM
Projekt 8E's Avatar
AudiWorld Expert
if you go to www.hrsprings.com it will tell you the range that their application goes.
Old Feb 11, 2004 | 08:01 AM
sbh tuned's Avatar
1.2 - 2.2 drop in the front means only a 1" range?
Old Feb 11, 2004 | 08:09 AM
Projekt 8E's Avatar
AudiWorld Expert
Default actually, that might just be max lowering between sport and non-sport. hell, I dunno cuz that's way
off. I dropped my car more than 2.2 inches and can go a lot lower still.
Old Feb 11, 2004 | 08:48 AM
Jet Jockey/A4 Pilot's Avatar
Default The range of 1.2 to 2.2 in adjustment is based on the OEM stock NON SPORT suspension only....
When you drop your car you must use a non sports pack car as a reference. Now of course the threaded housing will allow you to drop it more than the specified range from H&R but you are on your own. The specified range is there because H&R tested the kit that way. By dropping the car outside this range the shock/spring combo will not work effectively and under hard cornering or/and bumpy road conditions you will bottom out and hit the bump stops.
Old Feb 11, 2004 | 09:03 AM
Projekt 8E's Avatar
AudiWorld Expert
Default I've gone beyond the range and I did use non sport but fortunately I am not hitting the stops.
I did cut them in half though.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 11, 2004 | 09:12 AM
Default Ah ah, my friend, you cheated. Talk with Roger at H&R he will be in a better position to explain
The range issue to you. At least that's what he told me over two years ago.
obLu's Avatar
Default On my new installed H&R coils, rear height is the problem.
With it cranked all the way up, it's still about 1/4-1/2 lower than my stock sport.
Front isn't a problem, it could go higher than stock sport if I wanted it too. I noticed when the front is too high, it gets bouncy though.
For comparison, rear fender height is right around 25-1/4 with stock 17"'s.
