Cold Start Problem
Old Nov 26, 2005 | 11:46 AM
JKG's Avatar
JKG
New Member
Default Cold Start Problem
I know this is a FAQ, and I've searched, but I'm still having a problem narrowing the cause.
Stock 2000 A4 1.8TQ, 108k miles.
Cold starts, after sitting overnight, are very difficult. The engine cranks, but ignition is a problem. After several cranking attempts, car will eventually start, run rough for a few seconds, and then smooth out. Immediately after the start, the smell of raw gasoline is usually present. Warm starts during the day are no problem. Car performance is fine once it's started. Pulled engine fault codes with VAG-COM, and there are none except for an intermittent cruise control code.
I suspect that the battery may need replaced because the car cranks more slowly than I think it should--but it never fails to turn over. However, because it turns over, I'm not sure how the battery could be at fault.
One thing that is missing is the spin-up of the secondary air pump. Previously, the secondary air pump would activate immediately after startup, and occasionally when idle. It doesn't seem to activate at all now, though I'm not sure if ambient temperature plays a role or not. In any case, there are no engine fault codes pointing to the secondary air pump, so I assume that it's not being activated for some reason--not because it failed.
Did a quick check for vac leaks, and didn't see or hear anything obvious, though I assume that I'd get a fault code for a consistent lean condition at some point if the leak was big enough.
Does anyone have any ideas?
Thanks,
JKG
Old Nov 27, 2005 | 06:44 AM
a4tisâ„¢[Bye Turbo]'s Avatar
Senior Member
Default JoeyT - one of your sheep has wandered from the herd...(more)
Well cars sitting overnight in the cold will never crank the same as if they were garage kept. But it sounds like you might be having the same problem as me so have your ignition switch looked at. That's all I can think of at this point.
Also, post this in the B5 forum, they know more about your car.
Tom10
Audi A3 / S3 / RS 3
10
Jul 8, 2018 09:30 AM
KekePerkele
Jul 19, 2016 10:53 AM
raiderrider
12
Sep 8, 2015 05:46 AM
rammstien80
2.7T V6 Discussion
Sep 4, 2015 04:26 AM
aron56
Audi 100 / A6 (C4 Platform)
Sep 1, 2015 12:39 AM
