Door Control Module test?
Old Jul 13, 2013 | 07:11 PM
A4 in FF's Avatar
Default Door Control Module test?
This car is new to me and has several issues that I am trying to iron out. Here is the current dilemma I am working on:
I have no of any window from the drivers door, no window switch in passenger door (? missing when I bought it, replacement on it's way), rear passenger works normal at door, rear drivers doesn't work at all. I have continuity in all the wires through the door harness I also have power and ground at the DCM plug. I did a VAG COM scan (this was my first experience with the program so I am not real knowledgeable with it) and did not get communication with any door module.
Is there a way to test the Door Control Module? I don't want to start throwing parts at it since I am currently doing that with my wife's Land Rover!
Old Jul 15, 2013 | 05:32 AM
lyleswk's Avatar
Kind of hard to understand your post, but I think you are saying that none of your windows work except the rear passenger window from the rear door? Also, you are missing switches in the passenger door?
obtw, it's has been a while since I ran the VCDS, but I don't recall there being a "Door Control Module" in there. Further, don't believe there is anything but simple electrical circuitry running the windows (i.e. voltage, wiring, and switches), although the CCM (Comfort Comtrol Module) may be in the loop somewhere.
Old Jul 20, 2013 | 11:51 AM
A4 in FF's Avatar
Yeah, I missed the word control, as in "I have no control of any window..." I will try to clarify. No driver's window switches work, passenger door is missing the switch which I just received shipment of this week, rear drivers window doesn't work either from the door or the driver's door and the rear passenger side works on the door itself but not from the driver's door. It does not appear there are any other electrical malfunctions other than the windows
I tried channels (or maybe address is the right term) 42,52,62 and 72 in VCDS which were each labeled as an individual door. I got a no communication error with each one, maybe that's because my car doesn't use those channels, I don't know. I just ran an auto scan again and got an error 01331 under address 09 and 16 that reads
01331 - Door Control Module; Driver Side (J386)
49-10 - No Communications - Intermittent
There may be just "simple electrical circuitry running the windows" but it sure seems like there are a lot of people running into the same problem that haven't found, or more likely haven't posted, answers.
I'm just trying to work from the door in. I eliminated the harness as a suspect, now just trying to move on to the next thing and it seems like a lot of people suspect the door control module on the window motor. Given that I have a communication error with it I would like to try to confirm/eliminate it as the problem. My Bentley manual just arrived so now I'll have electrical diagrams to go off of.
Old Jul 20, 2013 | 03:41 PM
A4 in FF's Avatar
I took the passenger door apart to install the new switch and found the old switch was just pushed out of it's spot and hanging in the door. After reinstalling the switch that window works normal from the passenger seat. So my issue is no operation of the rear driver's side window and no working switches at the driver's door.
So there is no way to test the driver's door control module?
racheldela
Q5/SQ5 MKI (8R) Discussion
May 14, 2020 11:10 AM
Derryn
A6 (C7 Platform) Discussion
Oct 1, 2018 09:23 AM
Chris Salter
Apr 19, 2018 08:21 PM
tschoppe
Aug 14, 2017 07:11 AM
MC Hammered
Dec 25, 2008 04:54 PM
