Engine damage...
Old Sep 10, 2003 | 06:16 AM
PlumSmuggler's Avatar
Default Engine damage...
I have not said much about my broken down car in a while. I thought that I would share!
The car has been in the shop since the 11th of last month. 2 weeks ago I got it away from the one dumb *** dealer who changed my computer out and said it was fixed but had bad gas. Car had the same symptom as when I took it in originally. That next day I took it to a much larger and better dealer. He laughed at the other dealers feable attempts to repair and his dismissive "it's bad gas..." statement.
So after 2 weeks of daily troubleshotting, riding with the vag, talking with the factory daily and testing everything he has determined that cylinder 2 has a mechanical problem. When he accomplished a compression check he found cylinders 1,3 & 4 lost appx. 3% on the check ,acceptable; cylinder 2 lost over 16%. He now has the head removed and is checking the valves, piston and rings. Fun stuff, let me tell you.
Has ANYONE every had a problem like this? Know anyone who has!? I have a feeling that the engine might have had a manufacturing defect that took a while to show it's face...?????
Don't quote me on the percents on the compression check. He was trying to translate all the technical stuff to English for me becasue I don't speak technical German. At least I have a competent dealer working on it now.
Maybe the car will be fun and happy when it comes home from the garage! I miss it! (
Old Sep 10, 2003 | 06:17 AM
PhaZeIII's Avatar
Did they say anything about you being chipped?
Old Sep 10, 2003 | 06:22 AM
Default The chip is long gone...
The first dealer swapped the computer.
Old Sep 10, 2003 | 06:31 AM
dMang's Avatar
New Member
Default I don't think the problem has anything to do with being chipped...
It sucks that you paid all that money for the ECU upgrade. APR should have some kind of a guarantee that if ever the dealer changes the ECU to stock, APR will do the re-upgrade for free as long as they have the necessary proof that the ECU serial number matches what's in their records.
Old Sep 10, 2003 | 06:33 AM
PhaZeIII's Avatar
Default Sorry, what I meant was, did they ever try blaming the problem
on the chip when you initially brought it in?
Old Sep 10, 2003 | 06:53 AM
Default You are exactly right...
The chip had nothing to do with the problem. The symptom didn't change at all when the computer was changed.
I have been in contact with APR several times and they have been really helpful and are going to work with me should I choose to get another chip. I am kind of afraid though...
Old Sep 10, 2003 | 06:58 AM
No, they didn't even know. I had EMCS and I had the chip off.
Old Sep 10, 2003 | 07:02 AM
Boston1.8T's Avatar
hope you get your car fix soom
 Michael S. Palmer
Old Sep 10, 2003 | 07:28 AM
TonnyRat's Avatar
New Member
Default dealer did the same when i had a problem. swapped ECU and problem was still there.
he was set on blaming the chip when in fact it wasnt the problem. i did get a nice letter apologizing his behavior.
BTW i have GIAC chip
Old Sep 10, 2003 | 07:38 AM
lawong's Avatar
My friend bought a 2001 S4 that cracked cylinder. Instant lemon.
