Engine not working properly after changing timing belt and chain tensioner 1.8T
Old 04-28-2024, 02:42 AM
BNDR's Avatar
Default Engine not working properly after changing timing belt and chain tensioner 1.8T
Hello!
This is my first thread here.
I recently replaced timing belt and chain tensioner on my 1.8T 02 audi a4 and got some problems with starting, namely the car shakes when putting to D or R (automatic transmission) and an error code appeared P0012 and never came back after I deleted it.
To replace the timing belt, I decided to dismantle the bumper, remove the radiator, unplug the plugs and drain the coolant to have easier access. I took some pictures of how I installed and adjusted timing.. If anyone could give me advice on where to start diagnosing the problem and what could be the problem, I would be grateful.
Crankshaft
Camshaft (exhaust)
Camshaft (Exhaust)
Cmashaft (Intake)
should be 16 rollers between both cams
Old 04-28-2024, 04:02 AM
BNDR's Avatar
Default More info
Gr 93 shows engine load on 27.1% on idle and Phase Position Bank 1 Intake -8.0KW
Old 04-28-2024, 04:13 AM
JohnnyJ's Avatar
Recheck the timing belt position
Old 04-28-2024, 08:05 AM
Cybersombosis's Avatar
Any particular reason why you changed the cam chain tensioner out? Typically non-OEM ones fail early or don’t work properly. If you used an aftermarket one in, I suggest changing the pads over to your original one and putting it back in.
Richard_02
Audi A3 / S3 / RS 3
05-16-2017 10:11 PM
gahigalaba
06-04-2015 04:40 AM
gahigalaba
New Member Welcome Area
06-01-2015 11:34 AM
EuroV12
10-24-2013 06:40 PM
CHT
10-19-2001 02:49 PM
Quick Reply: Engine not working properly after changing timing belt and chain tensioner 1.8T
