Fan Control Module code issue
I did some searching and still have some questions, please help if you have some input
I got this code after scanning the car because the temp went throught the roof over the weekend:
18339 - Coolant Fan Control Module (J293): Malfunction
P1931 - 004 - No Signal/Communication - Intermittent
However today the fan worked and the temp was fine.
So does this control module go out over time? Is there a way to test it with VAG?
I found people talking about a 300 vs 600 watt unit, how will I know which the dealer is giving me? and is the attached DIY for a 300 or 600 watt version?<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/1047956.phtml">https://forums.audiworld.com/a4gen2/msgs/1047956.phtml</a</li></ul>
So I attempted to test the fans with the output test module in VAG. I skipped the other outputs to get the the 10th test which was the coolant fan level 1 test. When I run it nothing much happens. I hear clicking in the engine bay but the fans never turn on....
Am I running the test properly?
Also I can get the fan to run with the AC, is that wired differently, or does that complicate my problem? Or at least sometimes as the fans worked 2-3 times when I tested with the AC this morning, however now I cannot get them to kick on......
Thanks,
