Fault code help...
Old Nov 4, 2003 | 09:25 PM
Carfanatic(Darren)'s Avatar
Default Fault code help...
My roomate is having a problem with his DV, it seems as though it is not functioning, we initially thought that the valve just needed to be lubed, so we lubed the valve and it still did not work, the valve is not venting as usual, I hooked up my vag-com and pulled some codes from the car, we got the following codes:
3 DTCs Found:
16395 - Cam-Timing Adj. Bank 1: Advance Setpoint Not Reached
35-10 - - - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
17522 - O2S: B1 S2: Internal Resistance too High
I also found a vacuum line that was frayed, but the vacuum line is located under the intake manifold so it was impossible to get to, he is bringing it into the dealer tommorow, but we were wondering if a vacuum leak would cause all of the above as well as the DV not functioning (as the DV is hooked up to a vacuum source)
Any help would be great, His car is at 49,600 miles so he is almost out of warrantee
Thanks
PS: The car is a B5 2001.5 a4 1.8t Tip
Old Nov 5, 2003 | 07:37 AM
nexus617a4's Avatar
New Member
Default Try the VAG-COM forum.
<ul><li><a href="https://forums.audiworld.com/vag">https://forums.audiworld.com/vag</a</li></ul>
DanD.
A4 (B8 Platform) Discussion
10
Nov 25, 2016 03:35 AM
subterFUSE
S6 / RS6 (C7 Platform) Discussion
Sep 22, 2015 05:06 PM
csongi86
Sep 21, 2015 12:24 AM
tmac2015
Sep 20, 2015 04:29 PM
ericliquid
Sep 17, 2015 06:13 AM
