Fault Code Help
09- 1 fault
01800 - Light Switch (E1)
27-00 - Implausible Signal
Can some one clarify the meaning?
Also, I want to change the 09 module coding from 00013 to 00011 so the fogs will work without low beams. Is anyone familiar enough with the Ross Tech program to tell me how to change that coding?
Thank you!
You just want to recode that module. Once you go into that module you will see the option to recode. I would make a list of all your original codings incase you have problems and want to code back to stock.<ul><li><a href="http://www.ross-tech.com/vag-com/cars/audiB6.html">If you haven't already make sure you read this page.</a></li></ul>
Thank you very much.....like i said, i was a little tentative....having imput from one who knows helps!
