Headlight problems
Old Jan 13, 2020 | 05:43 PM
aladin's Avatar
Default Headlight problems
My driverside headlight assembly is completely out I move the bulbs to passenger side it works
Old Jan 14, 2020 | 12:32 PM
kjopen's Avatar
which headlights do you have?
Old Jan 14, 2020 | 12:51 PM
aladin's Avatar
halogen nothing works but that light next to blinker below headlights
Old Jan 14, 2020 | 03:21 PM
kjopen's Avatar
ah, mine are xenon and my ballast went giving similar problem - yours are different. If the bulb works when moving it to the other headlight then it sounds like the wiring is at fault or maybe the bulb holder? I had an A6 with halogens and had the same problem as you, I took the headlight itself out and connected it to the other headlight wiring to eliminate the wiring or holder - it was the holder itself that was faulty after this test in my case..
Old Jan 19, 2020 | 06:25 AM
kjopen's Avatar
Old Jan 19, 2020 | 08:35 AM
turbo510's Avatar
I think that he physically took both headlight assemblies out, and connected the "dead" one to the the harness plug on the "good" side. The headlight housing will of course not fit, but the connectors are identical and will show whether the problem is in the headlight assembly or not.
Old Jan 19, 2020 | 12:13 PM
kjopen's Avatar
yeah that's what I'd suggested, - just thought he might have given feedback...
LuvmyQ5
May 3, 2022 12:42 PM
Kyokio
Jan 28, 2008 01:57 PM
sweeTT
Feb 23, 2007 05:58 AM
SCarGo02
Dec 29, 2006 07:31 PM
stever254
Oct 16, 2006 06:56 AM
