Help!...Car Starts hesitating/jerking/surging while Accelerating in Chip mode (APR stage1+)....more
In chip mode,1st gear is ok,even on hard acceleration. But on 2nd gear or higher, the car starts to experience fast pulsing jerking and surges when rpm goes passed 3000.....enough to make the CEL warning to flash. After a while,the CEL dissapears...but will return if I try to Accelerate again on 2nd gear or Higher.
I got worried and switch back to stockmode for now.....To my surprise,everythings fine in stockmode, even when trying to accelerate hard.
Can anyone tell me what might be happening and whats causing the hesitating/jerking/surging and CEL to flash while accelerating ? (In Chip mode)
Yes, you have a coil pack failure. VAG-COM to find the cylinder # coil pack to replace.....
The reason it is happening in chipped mode and not stock mode, is because in chipped mode, the cylinder pressure is very much higher at the ignition point. The high pressure requires higher coil secondary voltage to force a spark to jump the spark plug gap, higher voltage than the coil pack secondary is able to achieve. It sparks OK, in stock mode because the cylinder pressure is a lot lower at the ignition point.
Maybe, but an injector with a problem won't behave differently with changes in boost..
pressure. (Boost pressure significantly effects the dynamic compression ratio/pressure)
The primary cause is inadequate specs on the electrical parts in the coil pack.
The higher secondary voltage generated by the coil pack when chipped is to much stain on the parts, and the properties for insulation resistance etc deteriorate, then fail. There is an "N" version cp available now also. Hopefully, that version will put this trouble down for good.
Coilpacks fail less frequently in stock engines.
