Help with my Motor mount install.......
Here is a pic from the tech section that shows how you should trace the original position of the nut anchoring the mm to the frame.
<img src="https://www.audiworld.com/tech/pics/eng57-mount3.jpg">
Here is a pic of how mine came out after I installed the new mount. I cant get it to line up in the original position. However, it feels like it seated correctly. Should I just move on? Perhaps its because its an aftermarket mount. Also, the mounts are interchangable from left to right, correct?
<img src="http://www.pbase.com/caseydc/image/40507634/original.jpg">
my understanding. motor mounts are what attaches motors to the frame of the car
you might have to use a jack to level the position of the engine since it looks like the engine dropped a bit based on your pic.
lastly, you might get better/faster responses at the B5 forum...gl...
Its fine, but a few comments......
Don't tighten the bottoms up until you've installed the right and left side mount. Let the engine rest in its natural position , then torque them to spec and you should not have a problem.
If your only replacing one mount(bad idea), it won't go back into its original postion becasue the other side is probably just as collapsed.
uble1234
14
10-23-2020 08:07 PM
hardipk5
10-02-2015 08:32 PM
