Help with plastic undertray removal!?!
Can anybody with a bentley CD post a diagram of where all the screws holding the plastic undertray(belly plate) in? Trying to put in a BPV, but gave up after 20 min of not being able to take the plastic part off. Is there anyway I could access the BPV easily from above? I already checked out Joe N.'s writeup on his TT BPV install, but I wanted more of a diagram. Thanks
no pics, but...
the undertray should have visible fasteners along the front and rear edges AND in the front of each whell well. you need to work your way around. i did all but the center front and center rear screws, then dropped those two, letting it fall on my face.
as far as getting at the valve, you need to come from the bottom if you do not pull the raditor core/bumper assm forward. there is no room to come from the top. from the bottom, it is a bit of a reach, but be patient. you will need to distroy the stock clips, so have all correct new ones before you start.
it was bit of a task, but the whole thing took less then a half hour.
good luck--
good luck--
uble1234
14
10-23-2020 08:07 PM
craigandjenn4
Q5/SQ5 MKI (8R) Discussion
09-27-2015 01:57 PM
