Hi, looking for instructions on how to remove Tiptronic selector lever..
I am replacing the white pull-up plastic piece inside part No.10. Anyone with Bently?? Thanks so much.
Jack
<img src="http://pictureposter.audiworld.com/1060/shifter.jpg">
Jack
DUDE! I've done this AND put it back on.
Be super careful. Just pull the button out as far as you can BUT NOT ALL THE WAY OUT keep it together if you can, and yank the leather **** away from the collar. You can't really put this back on once you pull the button out. I needed to put a special plastic shim in there to put it back together, but this is only if you ever want to put it back on later. Just a heads up.
It will come off, Just pull.
Thanks for the reply, but..
I am not referring to SPP tip mod>removing the stock leather shift, I got that part. I need to replace the whole white plastic tube unit, cause mine broke in half...I don't have access to Bently or any Audi repair manual..Someone with a VW told me is really easy to remove the whole shifter unit. However, after inspecting the unit, I don't really have any clue, I figure it will take me a few hours, just removing all other parts..
Jack
Jack
uble1234
14
10-23-2020 08:07 PM
craigandjenn4
Q5/SQ5 MKI (8R) Discussion
09-27-2015 01:57 PM
