High Pitched Hum when gas is low?
Old Jan 7, 2012 | 07:57 AM
abcxyzzz's Avatar
Default High Pitched Hum when gas is low?
Hi, I have a 2004 3.0L A4 Quattro. I bought this car used a couple of months ago. I noticed when the gas guage gets down to about 1/8th, sometimes when I push the accelerator, there will be a faint high-pitched hum coming from the mid-to-rear area of the car. It's rather annoying. After I fill up the car, the noise is gone completely. Is this common, anyone know what it is, and how I can get rid of it?
Thanks.
Old Jan 7, 2012 | 10:07 AM
turbo510's Avatar
Fuel pump. About $200 at autohausaz.
Old Jan 7, 2012 | 11:27 AM
abcxyzzz's Avatar
Can you elaborate a bit more? What is going wrong with the fuel pump and what would cause that make a humming noise only when the gas is low? Thanks.
Old Jan 7, 2012 | 01:15 PM
dubsport inc's Avatar
Change the fuel filter first before you do the pump.... it is known problem!
HTH
Richard
Old Jan 7, 2012 | 02:30 PM
Ritz's Avatar
I'll second the fuel filter change. Had similar issue that was resolved by filter change.
Old Jan 8, 2012 | 04:44 PM
abcxyzzz's Avatar
Thanks for the confirmation. I'm looking back at the service records I got when I purchased the car and on March 2009 (82,123 miles) and there is a service record of exactly the same thing (loud humming noise) - the dealer replaced the fuel filter.
Then 3 months later June 2009 (84,223 miles) same thing, the previous owner had the same noise happen and the record says, "found an extremely noisy fuel pump, upon removal of fuel line, it broke, had to replace line. And they replaced the fuel filter (again. - not sure how necessary that was being it was just replaced 3 months ago).
Now 2.5 years later, at 113k miles, it's back i guess. How come it keeps happening. Hope it's just the filter and not the pump. Pump and filter should last longer than 2.5 years and 28k miles
shouldn't it?
Also, how come the humming noise only happens when i'm low on gas (1/8 tank or less)?
Thanks for any insight!
Old Jan 9, 2012 | 07:21 AM
A4Audi4Fun's Avatar
Yes it should last longer but maybe you have very dirty gas in your area. Fuel is used to lubricate/cool the fuel pump. When level is low there isn't as much lubricant around? As the fuel level drops, the fuel tank probably acts as an echo chamber making any noise that exists sound louder. General consensus is don't run your fuel tank low.
Old Jan 9, 2012 | 07:54 AM
abcxyzzz's Avatar
I live in Southern California, Premium 91 has always been used in the car. I guess regardless if the gas tank is full or on low, if the fuel filter is clogged, then it's making the fuel pump work harder regardless of whether the gas tank is low (and makes noise) or full (and doesn't make noise)? So driving it right now will put more strain on the fuel pump?
I ordered a fuel filter, and will see what happens when I change that.
Any other input and thoughts are welcome and appreciated.
Thanks.
Old Jan 9, 2012 | 11:23 PM
abcxyzzz's Avatar
I've ordered a fuel filter MANN wk730/1. From the picture there is one 'pipe' on each end. I'm looking at other filters on the page and some have 2 pipes on one end. Did i order the wrong part? Is the filter supposed to have 1 or 2 connections pipes on each end?
Old Jan 10, 2012 | 04:27 AM
lyleswk's Avatar
Mine had 2 on each end.
ECS Tuning is down right now, but will get a link to the one I purchased about 6 months ago and works fine.
