High Pitched Hum when gas is low?
http://www.ecstuning.com/Audi-B6_A4-...h/Fuel_Filter/
http://www.autohausaz.com/search/pro...@Fuel%20Filter
Hmm...when i change the model of the car to a 1.8T Quattro, it comes up with the 2 pipe connection filter. So I gather your car is a 1.8T and not a 3.0?
The term "split" is regarding the year model. I changed the engine type and got a little different list from the ECS Tuning site although the one I used is still the first one. As far as what you need, you need crawl under the car and look at the filter which is what the Autohaus website tells you to do. I suspect you will find a 2 inlet and 2 outlet filter and unless you mod your car (and no, I have no idea how to mod), you will have to install Audi part.
Does anyone have a link to a DIY to change the fuel filter in a 2004 A4 Quattro 3.0L Avant?
Thanks.
http://www.audizine.com/forum/showth...ght=filter+diy
Anyway, i just picked up the car and he said there was nothing wrong with the old fuel filter and nothing clogged. Man, not sure why he didn't call me to tell me that because he replaced it anyway and charged me $62 for the part and then tossed the part her replaced even though it was good. I would've kept it. I hope he really replaced the part and not just put the old part back and charge me $62 for the part!!
He said that the whining would come from the fuel pump, not the filter (Audi Tek below said he's 100% sure the noise is from the filter), so I'm confused. The mechanic said if the pump is making noise it doesn't necessarily mean it's bad, he said if the whining noise changes from what it's doing now, then something might be going bad, otherwise I probably just have a noisy pump (it was replaced at the dealer just 2 years ago). Said nothing mechanically is wrong or harmful with that noise, and I would only notice a difference if the pump started failing as it woudln't pump sufficient fuel (so loss of power i guess), but if i don't notice anything different, then just leave it.
I won't know if it even still makes noise until i run the car down on gas, it's 3/4 full still.
Any thoughts or other experiences from you all?
I don't think the mechanic just visually looked at it to 'appear' fine, he said he blew through it and there was no restriction in flow. I sure hope the noise doesn't come back with this new filter (assuming he even changed it, since he said there was nothing wrong with the old one - yep, i'm not a very trusting person, esp with car repair shops
So what will happen if the pump fails and you're driving?
Also, being skeptical of your mechanic is a good thing. Have him prove that the filter is making a noise, such as lifting the car and letting you listen. I suspect that was BS.
