I got a 02 a4 v6 3.0l
Was running really rough when I bought it. Came to found out the camshaft breather vacuum line was broken. I replaced it it did good for a little bit then it started again. Need a little advice and some direction about how I should fix it or what I need to do
Hi, could be anything.
Did the preson you bought it from tell you anything about why it was running bad?
Are there any records on the car?
Some more information would be helpful.
How many miles on the engine?
Pull the engine codes with a reader. Find someone with a VAGcom and record all the engine codes.
Problem could be anything from bad spark plugs, coils., no compression, vacuum leak, bad MAF sensor,
RKsilver
48
06-27-2010 08:27 AM
Nappy
Audi allroad
13
06-09-2008 08:26 PM
rickyS4
08-23-2007 07:50 AM
