What does this brittle cable go to?
Old 11-03-2016, 04:23 PM
Kaivorth's Avatar
Default What does this brittle cable go to?
Anyone know what this is for? I currently have a P0411, could this be the culprit?. I'm not sure where this cable goes. Any guides on getting it fixed? I have another similar cable next to it too you can't see in the picture.
Old 11-04-2016, 07:31 AM
paul85's Avatar
looks like the sheathing on your vacuum line. Replace it if the rubber hose inside is brittle and cracking.
Old 11-04-2016, 07:33 AM
Kaivorth's Avatar
Any guides on this particular one? I can't really see where it goes or what to take off to get to it
Old 11-04-2016, 07:43 AM
paul85's Avatar
Not sure what engine you have. I can't tell also from this photo where it is located in your engine bay. The only reason I say vacuum line is because I just replaced all of the ones on my son's car and they looked identical to yours. I only have minor experience with the 3.0 liter engine. If that's what you have, there is a guide out there floating around that shows photos and gives step by step procedures for what to do and what you will need.
Old 11-04-2016, 07:53 AM
Kaivorth's Avatar
Ahhhh it's the 1.8T
Old 11-07-2016, 05:33 AM
lyleswk's Avatar
Not sure exactly where that is or which line you are talking about; is that the intake hose on the right forward side of the engine? And then which line: the large one, the vacuum line in the middle, or the braided one at the bottom.
Also, below is the troubleshooting guide for P0411:
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Symptoms
## Malfunction Indicator Light (MIL) ON
Possible Causes
## Fuel Pump Relay (J17) faulty
## Hoses/Pipes to/between Components faulty/clogged
## Secondary Air Injection Pump (V101) faulty
## Secondary Air Injection Pump Relay (J299) faulty
## Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
## Check Fuel Pump Relay (J17)
## Check Hoses/Pipes to/between Components ## Check Secondary Air Injection Hoses/Pipes for Carbonization
## Check Secondary Air Injection Pump (V101)
## Check Secondary Air Injection Pump Relay (J299)
## Check Secondary Air Injection Solenoid Valve (N112)
Old 11-07-2016, 05:39 AM
Kaivorth's Avatar
Possible Symptoms
Possible Causes
Possible Solutions
The braided on the bottom. I'm not sure what guide to use to get to it and replace the hose.
Old 11-07-2016, 02:37 PM
old guy2's Avatar
That would be the hose connecting your N249 boost pressure control valve to your diverter valve. It has nothing to do with a P0411.
Old 11-08-2016, 05:52 AM
paul85's Avatar
and is a vacuum line or same type of line that invariably gets brittle and goes bad. Replace those.
Old 11-08-2016, 05:55 AM
Kaivorth's Avatar
Suggestions for replacement hoses? What size are they, hopefully all the same
tomwu
09-14-2017 02:41 AM
BruzzeSwedeGT88
11-29-2007 05:39 PM
slightly disgruntled
08-26-2006 01:57 PM
Section-9
Audi 100 / A6 (C4 Platform)
07-27-2006 02:30 PM
StormChaser404
04-18-2002 12:43 PM
Quick Reply: What does this brittle cable go to?
