Need these parts for less. Anyone help?
16399 - Bank 1: Camshaft B (Exhaust): Advance Setpoint not Reached (Over-Retarded)
P0015 - 002 - Lower Limit Exceeded
I need one of these not both.
Which one of these is bank 1: Camshaft B ?
06C-103-107-D
06C-103-108-D
They are $699. Each new.
They are less than $200. used on Ebay. I dont want used ones. Don't know how long they will last.
The labor for this is the same as my TB labor.
This is going to cost me about $2200. including parts.
Water pump blew up also.
Water pump and gaskets are in the $2200.
Anyone know where to get these at a lower cost?
06C-103-107-D
06C-103-108-D
Thanks..........
06C-103-107-D
06C-103-108-D
06C-103-107-D
06C-103-108-D
Thanks..........
I don't assume anything.
That is the part number for my CAM timing case.
There are two in a 3.0L V6.
I need one but think $699. is a bit much for the part.
I don't want a used one because it will go bad sooner than a new one.
The code below is why I need the part.
Its bad so the engine timing is off.
You didn't mention any previous maintenance or running issue or if you tried to clear the code and see if it pops back up? I ask this because I have seen threads where people start getting this after a TB change and the problem was the belt was installed a tooth off. Or maybe you thoguht all this through...
TB was done at 98k the car has 122k now.
I dont think its TB related.
Cars is at Induktion.
When they take the motor apart to do the work they will check the TB and everything that would cause the code.
I am looking to find those part for less if possable.
06C-103-107-D
06C-103-108-D
06C-103-107-D
06C-103-108-D
Neo1130
07-23-2007 02:57 PM
MNGopher2004
10-23-2006 09:30 PM
DanAudi90
10-27-2004 04:45 PM
