Neuspeed Sport+Bilstein, stay with OEM Sport, or go H&R coilovers?
<center><img src="http://pictureposter.audiworld.com/1003/perfect_drop.jpg"></center><p>I like the sport ride but if I get 18s or 19s, I'm going to want that perfect drop.
I have the OEM sport but it seems just a tad high.
I've seen many user's pics with neuspeed+bilstein, but some seem to have lower front ride height than others. Some look great while others look raked.
THe pic above is H&R coilovers.
Stiffer is not so bad, but I don't want bone jarring stiff. I had bilsteins on my old jetta and they were stiff as hell at first but then loosened up a bit.
I don't know if the coilovers will be stiffer than the bilstein/neuspeed because I have no experience with them.
You can adjust the front ride height on the Neuspeed Bilstein Adj. Dampers...
You can also send them the Steve at Bilstein and he'll revalve them for you as much as you want to cater to your preferences. cheers! Mike
Neuspeed Sports and Neuspeed Bilstein Sports set at second lowest perch in front:
<img src="http://pictureposter.audiworld.com/57072/b6a4neuspeedbilstein-2.jpg">
<img src="http://pictureposter.audiworld.com/57072/b6a4construction-1.jpg">
Not a lot. Neuspeeds are 450lb/350lb and most street coilovers are about 450lb-500lb
The Bilstein PSS9s are probably the stiffest cheaper set at 525lbs give or take and the Stasis Motorsports are the shiatt at any rate you want (commonly 600lb/800lb). cheers! Mike
