programming keys
i tried some steps that i read about in one of the tech articles...
insert one key into ignition, turn one click forward.
insert other key into driver door and lock doors by turning the key to the right.
press the unlock button once.
while keeping the key in the door unlock the doors by turning the key to the left.
done.
i also just tried this procedure that i found in my manual...
press either button A (unlock button) or C (lock button) once.
now use the master key to unlock or lock the door manually.
done.
>> neither of these worked for my 03. any ideas?
2) roll down window, close door. (paranoia never leave key ignition with lock doors and windows up)
3) use second key to lock door. leave key in lock.
4) click unlock button on the second key, then use to key unlock the car. remove key.
5) open door.
6) turn off car.
7) test second key.
Then repeat for the key that was in the ignition.
2. insert key 1 into ingnition and turn to accessory.
3. Wait 5-7 seconds and then get out the driver side door.
4. close door and insert key 2 into the door and turn it to the right.
5. let the key turn back to the normal position.
6. press the unlock button X times *** (see below)
7. wait 6 seconds.
8. press the unlock button once more.
9. done.
*** - if neither of your keys are working press this one time to program the first key and press it two times when you program the second key. Think of it as telling the car "ok, this is my X set of keys."
*** - if you have one working key and one non-working key, then press the button 2 times.
Have one good remote and a brand new one I just got today, didnt have time to let the dealer do it figuring this would work.... doesnt.
Any other suggestions ?
2002 A4
help.....
