question....
Old Mar 4, 2004 | 12:45 PM
turbo_flipper's Avatar
Member
Default question....
so i was just helping a friend of mine fix her car (range rover) and i noticed that her oil was pretty high (~3/4 inch above the top mark on the dipstick)...she said that it was filled that high because the engine goes through oil pretty quick...will the extra oil be a problem for her and if so, what would the symptoms be? thanks
Old Mar 4, 2004 | 12:46 PM
paul_858's Avatar
AudiWorld Expert
depends on the motor, but potentially the oil will go through the exhaust system and foul up the cat
Old Mar 4, 2004 | 12:51 PM
Member
Thanks
Old Mar 4, 2004 | 02:36 PM
jgoot's Avatar
Junior Member
Too much oil = no bueno, you should add as needed.
Old Mar 4, 2004 | 03:05 PM
juliand's Avatar
New Member
Default Even worse.....
If the oil in the sump gets so high that it hits the crankshaft it will get whipped up into a froth. Froth = air in oil, oil pump pumps oil, not air = no lubrication = $$$$$$$.
Old Mar 4, 2004 | 07:01 PM
Audi Junkie's Avatar
Community Builder
Default One overfill is ok, if it's always over it's a problem.Consumption is due to the wrong light oil :o(
The overfilled oil will burn off faster anyway!Either use a 5w-40 synth year-round or the other way is to use as heavy an oil as climate will allow. 15w-40 diesel-rated oil that cleans great (Delvac 1300, Dello 400, Rotella or Pennzoil LL) or even a 20w-50 is a cheap way to get through summer(down to even 0 degrees for the Delvac 15w-40, Pennzoil LL is the heaviest 15w-40 HDEO). For winter, a lighter hi-quality 5w-30 dino oil like Pennzoil, Chevron Supreme or GTX (Hi-Mi?!) is bare minimum, winter only though! In summer heat, even the best 5w-30, like she is probally using now, will not work well. Ultimately, there is no substitute for a 5w-40 synth, except the 5w-50 Syntec which would be the best overall choice for year-round, imo. Tell her def to look for the new Mobil 1 SUV 5w-40 available soon, it is repackaged Delvac-1 her consumption will be about one-fourth of what shop oil does. If she really does not want to spend on the synth (changed every 6 months, up to 9000 mi), the amazing Syntec Blend 10w-40 will work all-year and is A3-rated for $2. A3 test is 280 hours in an oil-eating machine without make-up oil. API SL test is like 25 hours with make-up oil, big difference.
oldyellar
19
Jun 11, 2007 06:17 AM
qfrog Ti20
Apr 24, 2005 08:33 AM
