Radio Security Code
Old Dec 31, 2002 | 11:27 AM
blau_A_vier's Avatar
New Member
Default Radio Security Code
Anyone had to use their radio security code? Took my car in this morning to get a trunk light bulb replaced and as I was leaving, I noticed that the radio said SAFE. I remembered reading about this in the manual so I dug it out and attempted to enter the code. Only problem is that the card that normally shows the code (at the front of the radio manual) is BLANK!!!
Anyone know where this is *supposed* to get filled in? At the factory? At the VPC? At the dealership at delivery?
It is fixed now but the dealer had to contact AoA and that took almost 3 hours due to a computer glitch. PITA!!!
Needless to say I'm a little bummed that somewhere along the line, this was missed. May be worth checking your manual so you don't have to go through the same ordeal that I did...
Old Dec 31, 2002 | 11:31 AM
2tu®bos1mission's Avatar
The code is normally on a sticker in the spare tire well, it's also on the back of the radio.
Old Dec 31, 2002 | 11:46 AM
lawong's Avatar
Back of the radio? Wouldn't that defeat the purpose of being secure?
Old Dec 31, 2002 | 11:58 AM
New Member
Default Re: The code is normally on a sticker in the spare tire well, it's also on the back of the radio.
They pulled my radio to get a number from the side of it but this was only an ID number. That number then had to be put into the AoA computer to get the "real" code.
The tech also looked briefly in the trunk but did not find the code. Not really sure exactly where he looked though.
Old Dec 31, 2002 | 12:09 PM
byron  -  b'rizzle's Avatar
its also in your symphony owners manual... inside the first page
Old Jan 1, 2003 | 03:29 AM
Phil's Avatar
Default 02' & 03' SHOULD only need the code if the radio is put into another car....
Audi finally realized to KEEP the radio active if left in the same car when the power was removed. Saved MANY , MANY service calls and headaches for them.
Old Jan 1, 2003 | 10:50 AM
lordofluke's Avatar
New Member
The manual said this feature MAY be present, but when I tested, it wasn't
xkahn
Feb 8, 2018 10:43 AM
KevinLugnuts
Nov 27, 2015 04:43 AM
Monsoonenough
S4 (B8 Platform) Discussion
Oct 3, 2015 02:59 PM
mdkv5
A6 (C7 Platform) Discussion
Sep 16, 2015 01:09 AM
