Rear Bumper removal
OT - where'd you sig pic go?
<center><img src="http://pictureposter.audiworld.com/62248/sig.t.jpg"></center><p>
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/419821.phtml">https://forums.audiworld.com/a4gen2/msgs/419821.phtml</a</li></ul>
Re: Rear Bumper removal
I just installed a full Kerscher kit.
1)Remove the spare wheel compartment cover.
2)Remove the two nuts holding the black plastic trunk trim, just behind the spare.
3)Remove the four luggage net hold down clips.
4)Peel back the carpet from around the sides which is also pushed under the black plastic trunk trim. This is spring clipped in place. There are also two plastic screw clips in the top of the liner above the shock towers.
5)Behind the trim you will now see a vertical line of four nuts with plastic point covers on the protruding bolts. (Beneath the rear lights)There are also two more of these in a vertical line inboard of the four. (six total each side)pull off the plastic cap and remove the nuts.
6)Remove two screws underneath the valance, in board of the exhausts attaching the valance to the frame.
7)Remove two Torx screws each side inside the wheel well holding the carpet liner in place.
8)Remove the Torx screw that is behind the liner. This holds the valance.
9)The whole unit will now pull off in one piece.
Cmmartin23
26
08-23-2016 04:44 PM
Audi A8 Parting out 99 green A8
Joejoe8U2
01-21-2016 05:35 PM
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
Audi A5 OEM S5 Parts for Sale
mjr034
09-16-2015 10:39 AM
bilbo6209
10
09-04-2015 04:07 PM
