Remove catalytic converters
Old Jan 28, 2013 | 02:32 AM
brucelee's Avatar
Default Remove catalytic converters
Hi there,
i have a 2003 a4 quattro 1.8t. The emmisions control light has come up on the dash and instead of replacing the cat im going to get a test pipe for it. when i install the test pipe what will i need to do with the o2 sensors? just plug them back in? will the car run normally with the standard sensors plugged back in? cheers
Old Jan 28, 2013 | 03:21 AM
tofast2belast's Avatar
Originally Posted by brucelee
Hi there,
you will need to install something between the secondary O2 sensor and the cat/test pipe. you can go to pep boys and get 2 18mm spark plug defoulers and drill one all the way through so the O2 sensor can be screwed in
then screw the 2 together and install o2 sensor
Old Jan 29, 2013 | 03:04 AM
brucelee's Avatar
thanks for that, but what is the reasoning behind having to install two anti fouler? what will happen if i dont? thanks for your help
Old Jan 29, 2013 | 04:31 AM
uberwgn's Avatar
Super Moderator
Bruce, do you live in a country/state where there is a routine vehicle inspection?
Old Feb 4, 2013 | 03:10 AM
the reason is because if you just install the O2 sensor in without doing this, you will get a CEL for CAT malfunction efficiency. so by doing this, it takes the secondary O2 sensor out of the exhaust stream so that it reads differently than what the primary O2 sensor reads.
the ECU is looking for a difference between the 2 sensors and this is how it determines the cats efficiency.
this wouldn't matter on state inspection, rather emissions testing. if he has a cel it will fail, thus doing this mod will allow him to pass the emissions test.
Spinnetti
Jun 2, 2010 04:31 AM
AME Audi
Sep 1, 2007 06:42 PM
A4X4
Mar 18, 2004 09:58 AM
NorthWestQuattro
Dec 9, 2001 11:23 AM
xr4tic
Performance and Tuning
May 14, 2001 11:26 AM
