Repairs
Valve Cover Gasket: $132
Spark Plugs: $59
Timing Belt and Water pump: $385
Front Brake Pads and Brake fluid flush: $225
Front Suspension Arm: $125
If anyone could give me some insight, I would really appreciate it!!
Thanks
from what you described, it seemed that the diagnostic shop knows how to predict mechanical failures, that rings the BS detector.
Timing Belt and Water pump: $385 --> definitely ripoff, timing belt need not be changed unless you hit 60000 miles.
Front Brake Pads and Brake fluid flush: $225--> brake pads cost from 30 to 100(for a good one). brake fluid flush can be done at jiffy lube(although I don't recommend it) for like 30.
well just try another diagnostic bodyshop/dealer and see what happens.
As far as valve cover gasket, is it leaking. Only than should be replaced since manual does not show change interval. Don't know about the rest.
