Shifter issues, B6 6MT, won’t shift side to side
I was driving my A4 B6 6MT today, and all of a sudden the transaxle stopped doing anything when I push the shifter to the left or right, leaving me with nothing but 3rd and 4th gears.
The shifter will move all the way from one side to the other and back whether it’s forward as in 1st gear, or back as in 4th gear.
I haven’t had a chance to investigate yet, but it seems to work fine in the 2 gears I still have, so I’m hoping it’s a shifter issue that will be somewhat easily sorted rather than an internal trans issue.
Any insights or suggestions would be greatly appreciated.
Get underneath and see if you can look at the shift linkages...sometimes those buggers fall out...the bummer part is you may need to remove the heat shield/belly tray to see better...see attached photo...you can see where the shift linkages are found on side of transmission...
Slinger (10-14-2023)
nobodeuno
12-02-2006 08:01 AM
nobodeuno
30
03-09-2006 12:59 PM
JasonS4+Festicle
36
01-10-2006 01:02 PM
SlykmrS4
11-09-2004 07:33 AM
Adrien A4
09-20-2004 07:22 AM
