Snub Mount Installed
Well i installed the snub mount and looking back it wasnt that hard. The hardest part was fitting the snub onto the bracket. The hot water did actually help, thanks whoever suggested it. As for impressions. Shifting has significantly improved. It is much smoother than it was before. I do have engine vibrations at idle however. I will adjust that on another day, but all in all a worthwile mod.
<img src="http://pictureposter.audiworld.com/66831/apr_snub_mount_vs._stock.jpg">
<img src="http://pictureposter.audiworld.com/66831/snub_mount_installed.jpg">
If you just do that, the cup will be sitting on the top of the mount...
You want to make sure the mount is completely centered top and bottom or you'll get vibration. You can usually put your fingers around it to feel for space all around, but you dont want to just let the top of the cup rest on the mount. cheers! Mike
