Software question
Software I am using is APR's stage 1+. I checked with APR, GIAC and Neuspeed. They all agreed that car would perform better as software is setup for stk K03- I asked Neuspeed if I could buy their software- No was my answer.
GIAC didn't have anything and APR has the V-tune that can be used with VAG to set paramters of timing, boost, ignition, etc. Without a lot of guessing to where things should be set, anyone have any ideas on how to do this or get a closer match for my cars set up? Thanks!
I also had him install a new bearing, (machined 5mm) too. He said this is as large as he could go with this, (or a K04) turbo.
Really flows a lot of air and works very well- He also said it could handle a presure ratio of 2.5, (2=1 bar). I think this is around 24-25 pounds of boost. With software, I spike at 17-18 and fall back to 15.
Costs for entire machining, bearing, tipping, etc. is around $825. Bolts back the same and looks the same, (from the outside).
If interested, let me know.
I will send my ECU to them and have this done.
Very nice and knowledgeable. Thanks!
